I just bought a 1973 sidewinder 16' w/Mercruiser 140 and took it to the lake. It very quickly overheated. I then replaced the impeller which was, of course, completely shot. I also replaced the missing thermostat.
Now it warms up to about 160-180 degrees and stays constant until I push it hard. Then the temp climbs toward 260 on my gauge and I'm sure it would keep going if it let it. As soon as I back off the throttle the temp comes back down.
All the while the oil pressure reads fine (30-40psi)
Compression is 120,120,115,118
Could any of these be the problem?
Any suggestions on the overheating? did I ruin the impeller when i replaced it? Could it be the circulating pump? Could a fuel starved lean situation overwhelm the cooling system? Maybe I'm frothing my over-full crank-case oil and collapsing my lifters?
Thanks in advance for any help!.
Jeff
- When I replaced the impeller, I left out the plastic guide tube which had melted from the previous overheat. My understanding is that this is only used to ease reassembly(?)
- I also didn't pay attention to which direction i flexed the impeller fins when I put it in the housing. I was told that they would flip themselves around as soon as you start the engine.
- The oil level is a quarter inch above full on the dipstick.
- The engine maxes out at 4000 rpm WOT while surging and sounding generally ill. (I am going to troubleshoot this problem separately, but I mention it here in case it may be related)
- There is a slight drip of water running down the side of the block under the manifold
Jeff
