black sheep
- Joined
- Dec 3, 2008
- 38
I removed the props from my 1973 slickcraft SS 235 with twin mercruiser 140 motors and outdives. When I returned to install them on the drive shaft I installed the thrust washer, propeller, castle nut, lock washer and then the nut. I noticed the castle nut would not slide over the splines of the drive line. I tried to push it on further to gain as much space as possible but failed to do so. I do not remember if it was slid over the drive shaft splines or not when I removed the props. Can anyone tell me if it is suposed to be slid onto the splines of the drive shaft? The castle nut has teeth in the center that match the splines on the shaft.
