I have a mercruiser 140. I just gave it a complete tune-up. Plugs, wires points, condenser, roter button, fuel filter and replaced the water pump in the foot. All gaps are set per engine specs. I took the boat out for a test run. It ran great for about 30 min. then started surging. Does any one have any ideas?<br />Also when I shut the boat off to check the point gap. I told my friend to hit the ignition and the starter stuck in the on position and kept turning over and over until the battery ran dead. I assume its a bad solenoid. Any other Ideas?<br /><br /> thanks<br /> Robert
