I have recently purchased a pristene 1966 Starcraft with a 150HP Mercruiser I/O inline 6 cyl. Chevy. Within 15 to 30 minutes of run time it fries the points for some reason? I am using all Mercruiser parts. I've changed the points, plugs, condensor, rotor, and coil. Points and coil several times. Engine runs fine until it just stops because of lost fire through the points? Oddest thing, seems to happen most often when making a hard turn? Could it be my alternater putting out too much juice at periodic times causing some type of weird voltage spike? What about the resister wire the manual says it has? How do I know where it is and if it is OK? Can I replace the resister wire with standard wire and then use an automotive external resister, and automotive coil, to cut the voltage to the points back below 12 volts? ( I know I would need an additional wire from the starter solenoid + post for the initial start up voltage ). Boat is super nice, but I'm getting tired of paddling it back in. Hope someone out there can help me out of this mess. Thanks so much, Dave
