Mercruiser 165 alternator mashup?
flashback
The alternator is cooled by a fan and fumes in the bilge will be pulled into it. It has spark from the brushes that could have blown you up. The marine alt has screens in the vents that are meant to dissipate any flame. I believe the aircraft industry uses oil cooled units. Jmho
will a DB Electrical 400-12007 1-Wire Marine Alternator 42 amp work in its place?
Ayuh,...... Welcome Aboard,..... Yes, that'll work,.....
It looks exactly like the one in yer attachments, which is a screen protected marine unit,....
FarmYard
Thanks for all the replies. Yes, I wouldn't put an auto starter in a boat. I just picked up this boat and am redoing everything. Mabey the last guy mashed 2 alternators together because I ripped out so much stereo equipment and wires. It even had a electric fuel pump wired in totally wrong, not the right carb with a Mr. Gasket carb spacer that did not even cover the manifold hole, no shift switch interrupt, and countless other hackery. The Sealoc stern drive repair manual is getting put to good use. I'm gonna save this 1978 Apollo relic one way or another.
