yjanray
- Joined
- Jul 30, 2009
- 257
So I was working on changing the impeller on my 165 outdrive MC-1 (boat and engine in my signature), and had issues getting the zinc anode off, then issues getting the propeller off, issue after issue.
Anyway, I finally got the propeller off, and drained the gear lube. I have water in the lube, but once I got the prop off, i noticed a pool of nice fresh high performance "green" gear lube in the bottom of where the through prop exhaust water would run. It is kinda hard to explain where it is, but I am planning on splitting the drive, replacing the water pump assembly and seals in there. Just trying to get an idea what would cause this before I get the thing apart. Below is a picture of what i am talking about.
Thanks
Yorke
Thanks
Yorke
