nomrwrk
- Joined
- Feb 21, 2011
- 51
After reading many past posts, I recently serviced my impeller and outdrive. After three attempts :facepalm: to correctly install the outdrive, I think I got it right. The 1st attempt, all gears were locked and couldn't move the prop. My 2nd attempt left me without reverse gear. My 3rd attempt, everything seems correct: forward gear, prop locks counter clockwise and rotates clockwise; neutral gear, prop spins freely in both directions; reverse gear, prop locks clockwise and rotates counter clockwise. However, when I'm in forward and rotate the prop clockwise, it seems make a slight grind sound, then pop's forward. The same thing happens in reverse when I rotate the prop counter clockwise. I presume this is caused from the gear teeth engaging without SAE 90W gear oil in the outdrive. Here are some pics to show my setup prior to installation. Can anyone help me confirm that I have the outdrive properly assembled and installed correctly? Thanks!
This is my outdrive
The lower half of the outdrive with it locked in forward gear
I have the prop off, so I used a heavy pipe wrench to keep the prop from rotating clockwise when I reassembled the outdrive
I have the foot in forward gear
I have the shift cable in forward gear
This is my outdrive
