Howdy.
Hoping someone can help shed some light on my concern here. I'm new to boating and this is my first craft. So please bear with me. I'm fairly handy and I plan on doing a lot of work myself.
My Mercruiser 165HP 6cyl (old school from 75 - I believe its Ford) with a early version Alpha one driver is running seriously hot in the this one particular area where the exhaust manifold connects to the block. I have it circled red in image attached.
I was on the lake yesterday cruising around for several hours and when I checked with an IR gun on that area, it showed 405F! I was running around 3000rpms. Needless to say, this scared me and I went straight back to the dock.
The thing is the engine water temp on the gauge is always reading normal. 145 -165 when running and idling around 145 or lower. I trust this reading because I replaced the temp sender and it matches when I check on the block with an IR gun.
I've also checked around the entire engine block with and there are no temps higher than 170 at any point on the block.
This particular area that is running this hot is also pretty rusted up and I'm guessing its because of the excessive heat. I'm suspecting this is not normal and something is amiss. This is my first boat and it being a restored antique, I'm trying to take good care of everything. Especially the engine. My question is this normal? Seeing such high temps as 400F anywhere on the block? Or should I take things apart to figure out what's going on?
Any suggestions would be greatly appreciated.
