newbieboater1
- Joined
- May 17, 2010
- 12
Hello all, and thank you for your time. I have a 1985 Century Palomino that I spent three months replacing the stringers, transom, etc.. However, this is an engine related question. My engine is a mercruiser 170 (yeah, I know its not a great motor, but it used to run great). I originally suspected a fuel delvery issue, but I was wrong and it was the carb that needed rebuilt, (but during my troubleshooting I bought and installed) a new fuel pump for it anyways. The new pump lasted approximately 16 hours before I began losing fuel pressure (I have a pressure gauge between the pump and the carb). The higher the engine RPM's, the lower my fuel pressure got (until popping/backfiring through the carb). I suspected the carb again (this carb has been a pain). However, when I tore the carb apart it only had a small amount of fuel in it, and when I pumped the throttle I only got a small rickle of gas from the jets. I suspected a line blockage, and ran the fuel pump directly to an external tank, but with little success. It would pump fuel, but not enough. Then I though that I should inspect the new fuel pump. Perhaps I installed it wrong. When I removed it from the engine, I found deep scarring (and severe wear) on the armature, and my cam lobe is nearly completely scored off. I know that the cam lobe was nearly perfect before I installed the pump because I inspected the lobe for damage after suspecting the old fuel pump for problems. I did note that the new fuel pump armature was radically different than the original, but NAPA told me that this is the correct pump for my engine (yes, it is a marine pump). I have included some photos of the original pump, and the new pump.
The first photo is of the two different pump arms, and the second photo is of the scoring on the new pump arm. The original pump's arm had very little
(if any) wear (and for being 20+ year old, I thought it was in great shape).
Napa and the local mercruiser dealership have no clue as to why this happened, do any of you? Please forgive me if I am confusing and/or incomplete.. My kids are running around trying to kill eachother while I'm typing this.
Thanks again!
Thanks again!
