I have removed the two bolts that go thru the flywheel housing to the starter flange and the two bolts that attach the bracket to the engine block at the other end of the starter. All wires have been removed as well. The starter is still tight in the fywheel housing. I have tapped the starter with a 2x2 and a hammer, but it did not move. Are there other bolts that I missed or is it just stuck in the housing? If the starter is just stuck, what should I spray on it and where is the best place to spray it. Also is there a place to put a jack screw or pry the starter flange without damaging the flywheel housing. Would appreciate any suggestions for freeing up the starter.
