I'm lost and need help. I'm a semi mechanic so I'm very mechanical savy, but my Mercruiser 2.5 is giving me a migraine and I can't figure it out. I don't know why, but the boat runs flawlessly at an idle or even higher rpms with no load, as soon as the load gets on the engine it will run about 10 seconds and die out like it's starving for fuel, and even once it starts dying it won't catch itself. Both jets seem to be working fine. Not sure if the choke is working. I'm not sure how to test it. Odd part is, I had it in the water a few days ago and it ran fine, no issues whatsoever. I took on a rope on the prop and it got warm, not overheated but warm and it hasn't ran right since. Doesn't get hot after clearing it and compression is good across the board.. what is going on with my boat?
