1982 Starfire with Mercruiser 228 and small block Chevy motor. Serial # 5923758 1.5R Dont have too much history on it. New impeller installed and no thermostat right now but its still overheating. I'm getting water out of the exhaust and I have pulled the hoses one at a time and each has water flow. I know the boat has seen saltwater in the past. I'm thinking that its probably in the exhaust risers or manafolds. I am going to pull them and clean them out. Any other thoughts as to what could be causing the overheating? I can hear the water boiling in the block. The temp rises to over 180 in only 3-5 minutes when running on muffs. Secondary question is what is the best way to clean the risers. I was thinking of having them sandblasted. Thanks for your help...
