111
ziggy Admiral Joined Jun 30, 2004 Messages 7,473 Aug 15, 2008 #2 Re: Mercruiser 228 starting problems are you using the 6-7 year old gas that's in the boat? perhaps it's not flammable anymore...
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,480 Aug 15, 2008 #3 Re: Mercruiser 228 starting problems run off a remote tank(outboard) to check the engine, then drain and clean the tank and replace any fuel seps or filters
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,357 Aug 15, 2008 #4 Re: Mercruiser 228 starting problems I have checked the oil, charged the batteries and cleaned the spark plugs. Click to expand... Ayuh,..... You might want to do a Real,+ Complete Tune Up..... Change the Plugs, Cap, Rotor, Points,+ Condenser,... Set the Timing,+ Dwell.... Also change the Fuel Filters,+ it sounds like the Carb needs a Rebuild or Replacement.....
