My boat is an 87 Chris Craft 196 LTD BR with the Mercruiser 230 Alpha 1. This summer I've been getting a LOT of water coming through the transom. The bilge pump has been handling it, but I'm worried that it won't one of these days.
I've leaned way down there when we're in the water to see if I can identify where its coming in but I can just see it running down the transom from the bottom of the bell housing (on the inside of the engine compartment). The bellows appear to be intact.
I've never take an outdrive off and not sure where to even start. Could you guys point me in the right direction? I have the service manual for the outdrive. It looks like there's a bell housing gasket kit that's less than $10. That sounded like a likely culprit to me. What else should I replace while I have the outdrive off? Will I need any special tools?
Thanks so much!
Chris
Thanks so much!
Chris
