holorinhal
- Joined
- May 26, 2009
- 119
81 mercruiser 260/alpha, with EMI thunder exhaust, SS risers. 160* thermostat.
So the temp gauge reads from 160-175 ish when running at speed, then creeps up to around 210, when i come down to an idle or flat wake.
A couple weeks ago, i had two sections of exhaust water boot, melt and get holes in them, in the lower section at the exhaust tip and upper down tube, on the starboard side.
i can hold my hand on the very top of the riser for a good while, but as i go further stern ward and down to the exhaust tip, it gets quite a bit hotter.
i can hold my hand under the exiting water for only a few couple of seconds.
i have used a laser temp gun and shot the temps on top of the risers and various other spots.
the top of the risers read about 97*, the lower portion of the exhaust tubes read quite a bit hotter and the block and heads read around 180 or less, if i remember correctly.
The wet exhaust hose or boots are about 5 years old.
is any of this out of the ordinary? Does any one have any ideas asto the issue?
Thanks
Thanks
