I had a post on here about a rebuild, the rebuild is complete and I had the boat out this weekend. A little info on the engine...'96 350 block with '84 components, basically a mercruiser 5.7 with a newer block - the old one cracked. Ran great all day except for dying on me three times. The third time it would not start back up. The first two times it died, it took a while to get it started back up and even had to play with the timing a bit, luckily I brought a friend's timing light with me.
So I get it home today, drain the oil, it was black and smelled like gas. Put new oil in it with a small amount of seafoam, and it started right up. I did notice two small water leaks on the port side of the engine at the rubber couplings on the exhaust lines. I also manually played with the throttle up and down and noticed the throttle adjustment screw was WAY off. I throttled the engine up and came down quickly and it killed the engine. So I adjusted the screw and that's good now.
After all that and letting it get to operating temp (around 150 deg) and letting it run at operating temp for 10 min, I turned it off and drained the oil. It looked like brand new oil coming out and didn't smell of gas at all. So was that screw my problem the whole time? I thought the fuel pump may have been bad but I'm wondering if I flooded the engine trying to start it so much. Any thoughts?
