Hey guys so I have got about 10 hours on the boat since I bought it and it has run 100% every time except some high rpm restrictions limiting the motor to about 4,000rpm. Runs hard to than till it just stops accelerating. I'm getting about 45 mph out of 4,000 rpm on a 19p prop which I see on here is pretty good
Fast forward to last Sunday I run it trying to beat the rain at about 3700 rpm (about 43mpg on GPS) and make it to the marina I get my truck and come back and the engine stalled. Will NOT start at all.
I smell fuel so I think that's OK
I check the voltage at the coil and I'm getting 5 volts after the ignition ballist. Before that part im seeing 11 volts and my battery is a little over 12 volts.
I'm not getting any spark and I tried swapping out the coil (new two months ago Sierra model) with the old one that I replaced just to replace it as a tune up. Same problem. I put a screw driver in the coils wire and I get no spark to ground.
The boat as a Mallory distributor says its magnetic electric and has three wires coming out and all look ok. All the wires look fine no fraying.
The motor (and boat) is a 1985 mercruiser 260 5.7 v8 model
When I'm cranking the boat the voltage at the + side of the coil to ground is less than 4 volts
