Re: Mercruiser 260 idle Temp on muffs??
Do you have the Mercruiser manual for your engine? It's Manual #3, 1978-1984 Engines - 4,L6,V8.
If not, post a question asking if anyone has a link to it. There are lots of them you can download free on 4share I believe.
This is the cooling system diagram from it:
Only way I know to verify the gauge is to check it with another one.
Start with the flow test in the manual to make sure you're getting enough water to the engine. If not, your problem is in the drive, a clogged oil cooler, etc.
If the flow test is OK, then your problem is the engine. Make sure your timing is set correctly. Verify that all the hoses are hooked up correctly, it's fairly easy to swap the ones between the manifolds and risers. Make sure the little flow check balls that are in the "T" where the riser hoses connect to the manifold are present and the springs are tight. If they're loose, they'll let your water go out the risers instead of through the engine. I spent a couple of weeks chasing that one down one time.
