OK so I got this boat. I took it out on the bay and it was running perfectly fine at low rpm. I got out of the harbor and went 3/4 throttle, and the temperature went from low green to red immediately and started smoking from the engine. I went in the engine compartment and could see the hoses going to the thermostat appeared to be jerking like it was trying to suck on something turned it off let it cool down and turned it back on and it ran fine again at low rpm, but I didn’t want to risk sending it into higher RPMs again. What could’ve caused this issue? What should I do from here? I’m deploying at the end of next month and I’m trying to get as much time on the water as possible. Lol so any help is greatly appreciated.
