working on a built 350 for my boat. they rebuilt it with a 78 block, flat top pistons, mild cam aftermarket heads, edlbrock intake. when I got the engine it had a quadrojet 4 barrel carb on it, ran fine. I switched out the carb for a edlbrock and when I checked the timing it was bout 2 inches above the numbers on the cover. when I tried to bring it down to 8 degrees it would die. I took the boat out and seemed to run fine but something kept tugging at me. so last weekend I did my comprehension test on it, new plugs, oil change and talked the timing again. I adjusted it towards the 8 degree and adjusted the idle as I got closer and it would want to die. I got it to 8 degrees Idling a smooth 600 rpm and seems to turn over better and still revs fine and sounds good. I haven't taken it to the river yet to test on load but does any of this make sense to you all? the man said it was built to about 330 hp if that adds to anything. Is there anything I should check to make sure I have this timing right. it does have the thunder bolt ignition on it. thanks in advance.
