Mercruiser 3.0 Engine mount adjustment
Pikey23
Hi,
I purchased the alignment tool and checked it. It is a little hard to go in. The grease marks are heavier on the top than on the bottom. So reading Don's sticky I figure that I need to move the front of the motor down. My problem is that I can not get a wrench in there to move the nuts. I can get to the top 1 1/4" nut on an angle and my be able to loosen that one. But there is no way that I can get a wrench on to either of the bottom two. Any suggestions would be great. Thank you in advance.
here is a link of what my mount looks like
http://www.boats.net/parts/search/Merc2/Mercruiser/140%20-%20%28GM%20181CID%203.0L%20I4%29/6229718%20THRU%200B450800%20%281982-1986%29/ENGINE%20MOUNTING%20%28FRONT%29/parts.html
Rocky_Road
Re: Mercruiser 3.0 Engine mount adjustment
You can use a 'crows foot' wrench with the appropiate extension:
Pikey23
ahh, Good idea! I will try to locate one large enough as my set only goes up to 7/8".
Rocky_Road
A set? You are a bonafide gearhead...most people have never seen their first one, much less own a set.
Happy boating!
Pikey23
Yes, I guess that I am a gear head. I have all the tools I need to work on a car. The problem is the special tools needed to work on boats. If I need a specialty tool to work on a car I can rent it. It would be pretty cool if there was a place that rented specialty boat tools.
