I have a 2001 Bayliner Capri 1950 that has a Mercruiser 3.0 and uses a Merc carb #3310-807504A1. I bought the boat last year (1st time boater) and ran it for the year to see if I would enjoy boating. The boat ran fine for the most part but it was hard starting it at times, both cold and hot. I decided to rebuild the carb this year.
I got the kit from Mikes Carb shop online and proceeded to tear it down. First thing I noticed was the choke was wide open and would not move at all. Answer to hard starts when cold! I actually had to remove the butterfly plate on the choke and heat the shaft ends and force the shaft out. It was really stuck in place. I took every part down and cleaned them well and then proceeded to rebuild. I have 2 excellent resources at work that assisted when I had questions and I am very confident that the carb went back together properly with all adjustments made correctly. I cleaned the shafts and greased them a little to make sure they wouldn't freeze again.
The boat started right up when done, however it was idling high(1100rpm). It ran great for the test run. I was so pleased that it fired right up every time, even with a dead alternator! That's another story but a new one is now on the boat. I tried to adjust the idle using the idle screw and idle screw on the throttle but couldn't get it below 900 without it really running rough. I read through some more info and realized that I should disconnect the throttle while doing this. I have the idle down to 750-800 and it runs pretty well at that, however it is supposed to be 650-700.
I checked for vacuum leaks, bad wires, etc using a spray bottle with soapy water. Wires are all good, no changes in idle when wet. I retightened all carb bolts and sprayed and again, no changes in idle. I can get the motor to 650 but it runs like crap and usually dies.
Does the 3.0 really idle well at 650rpm? Should I just leave it at 750-800 and go with that? Any ideas what to check that may improve idle at lower rate? All filters and fluids are new. New plugs, rebuilt carb, gas is good. New alternator, good battery.
Thanks for any advice
Dave
Dave
