I have had bad luck with the 3.0, rebuilt my engine and it flattened two cams on same lobe, a lot of you helped me trouble shoot that thank you. I have up on that engine and bought another boat for the motor.
i pulled the motor out of the donor boat swapped everything external from my motor onto it, ran it out of the boat and in my boat before taking it to the lake. I took it out today and it did great for the first half hour then when I was running at about 4000 rpm for about 10 minutes it last power and went down to 3400 rpm but kept running, and a ticking noise from the top of the motor. I pulled back the throttle and ran at 3200 rpm with no noise. I shut it off and looked it over with nothing obvious found. Started it up and repeated with same results, so again shut it down for about 30 minutes and ran it for the next few hours at 3200 rpm with no noise and no loss of power. Then took a break for an hour and went back out and ran it for an hour at 3800 rpm all good,let it sit for an hour while I fished then agin ran it for an hour at 3800 rpm and still no issues. Long winded I know sorry.
do you think a lifter just needed pumped up? The tag on the motor said I can run 4000 rpm but is that realistic? Any other thoughts or ideas?
