javabeaver
- Joined
- Apr 24, 2014
- 9
Boat dead when idling in water. Had to tow it back.
Turn key to run position, no beep. Normally it would give a long beep. Then I would start the engine. Now when I turn key to start, engine would crank but wont' turn on. Not battery issue. Charged battery, and also tried two car batteries. Oil pressure gauge only moved slightly when turn key to run. Other gauges appears working fine. Measured at the key starter, the wire from engine had voltage of 3V to 0.8V, not stable. The print on the beeper shows voltage 5V to 15V to sound. I connected it to a 9V battery, made constant sound. It looks like problem is with oil pressure reading.
Spent more than 2 hours around engine, couldn't find the oil pressure sender. Tried to find the service manual, but couldn't find one for the exact engine I have. I must have a weird engine.
I did find some information of 3.0L Mercruiser, but apparently it was for 3.0 TKS. The oil pressure sensor would be between the oil pump and starter. But the engine I have is 3.0 MPI ECT. No oil pressure sensor at that spot.
I would really appreciate anyone could point me where the oil pressure sender is. Or if there is any other test I could do.
Engine: 2012 Mercruiser
Information from the sticker on top of the engine.
Model: MCM 3.0 MPI
Displacement :3.0L (181 CID)
Engine rotation: LH
Engine Serial number: 2A04####
Model: MCM 3.0 MPI
Engine rotation: LH
