Chemdawg
- Joined
- Aug 31, 2013
- 112
Got something kind of interesting going on here. I discovered an oil leak just recently, and was wondering if this is a common place.
When I discovered the leak, there was oil down in the well below the motor. So I cleaned everything up really good, and placed some paper towel down there to see where it was leaking from. I know it's not coming from the tail end of the motor, nor the timing cover. It appears to be leaking from the drain plug. I tightened it down a bit more, and it still leaks. Was there a gasket or something on the drain plug that may have been lost when I did the oil change?
Is this a common area that a leak can occur?
