Mercruiser 3.0 'REBUILD'
Status
Not open for further replies.
Chris Hays
Just thought id throw a few pics up of the engine part of my boat resto, this is an extremely low houred unit, the only thing this boat had from new was neglect, when i got it i decided to pull the head (better safe than sorry, especially on the water!!), as the manifold riser gasket was bad and sure enough i had a nasty rust ring in #4. It was to deep a pitting to rub out with the hone so i stripped the block and got a liner stuck in it, went back with all new rings, shells and gaskets, then gave her a lovely paint job if i do say so myself.
Block back from machine shop.
Bottom view.
Crank, cam and pistons back in.
Head back on.
All buttoned up and masked ready for paint.
All done, ready to stick manifold back on and get it back in boat and running.
JustJason
Re: Mercruiser 3.0 'rebuild'
Nice work man... and best of luck!!......
but holy friggen oil filter!!!!!!!!
Might as well keep that one for break in..... but in the future... Pick up a Napa brand or Wix brand filter..... They are alot better than the STP brand.... at 1/4 of that size.
Ayuh,... I Agree,.. That wouldn't even Fit into most motorboxes....
Speaking of Fit,..??....
How about you Resize,+ Repost these pictures.... Something like 380x460 or something...
Personally,....
When I find a thread like this,... I only look Once... I Hate side-scrolling...
captmello
That motor looks great!! Where's the other 4 cylinders?;)
Bondo:
Personally,....
If the pics are to big, Hold down your Ctrl key and roll wheel on your mouse to zoom in and out.
Alumarine
zoom in and out.
But then the text is too small to read.
captmello
Huhh. Those original Photos fit perfect on my 22" monitor at 100% zoom.
Can the original poster tell us what the size of those photos are?
By the way I like the oil filter, but would look nice painted black too.
chiefalen
Man where did you get that oil filter ?
It's a joke right ?
Off a diesel or something, don't even use one that big on planes.
D
DJ
Guest
Beeeeeautiful! Nice work!:cool:
I have to agree on the oil filter. It MAY not fit in the boat.;)
I have an oil filter comparison kit sitting on my shelf. It has eight different brands in it. NAPA (Gold) and WIX are #'s 5 and 6 with Fram bringing up the bottom.
By far, the OEM brands regardless of make, are far superior. In your case the easiest to cross ref. would be an A/C Delco. A few extra sheckles isn't going to break anyone.
ziggy
food for thought. i don't see the hone doing a cross hatch pattern on th cyl. walls.... maybe it's my misunderstanding of a proper final honing of cylinder walls... not that i know that much about it... maybe it ain't that important....
it does look like new... sweet...
Chris Hays
That's not an oil filter its a remote reservoir like a corvette!!!,:p Yeah, shes some oil filter ain't she!!! lmao.:D The one i took off this engine was the same size and when i crossed the number at the parts store they gave me this, so i guess it'll do for the break in. Sorry for the picture size, its ok on my PC screen but when i checked on my laptop i see what u mean!! (Now re-sized!!;)) The pistons don't have any carbon on them as i got all that off, all you see is a slight discolouration from the combustion process, but good tip on the diesel cleaning, that'll remove many stubborn things, inc paint from skin!! (oops did i say that!!).;) The cyl walls do have the correct 45 degree cross hatch oil retention surfacing performed by the shop who did my sleeve, btw. My manifold gasket set should arrive this week along with a carb kit, and from Ebay a fuel pump and the plate that bolts to the flywheel housing and covers the front lower half of it, so once i get these on shes ready for the boat and initial firing up!! :D
Big Boat Bay Buster
I love engine rebuild pics. Especially the older mercruisers coming back to life for a second go around. Everything looks perfect-Good luck with it.
Chris
Chris Hays
A couple more 'shiny' pics!!
Chris Hays
A bit more progress made on the engine this week, here's a pic of it before the manifold was fitted.
And its on!!
Rebuilt carb not looking so pretty but, will do all the 'tarting' up later, i need this thing going!!:(
Alright, off the stand, flywheel and bellhousing fitted, electrical harness re-fitted, brandnew fuel pump, riser bolted on, she's ready for the boat just about!! ;)
nowback
Re: Mercruiser 3.0 'REBUILD'
is it common for the #4 to get water into it?
I am looking at a boat that has the same problem and i was
thinking of getting and doing a rebuild on it.
I am a little worried that it isnt a gasket problem that caused
the damage and that maybe its the exhaust or something
that will cost to much to fix.
btw what did it cost to do the re sleeve?
thanks
matt
victorc1
:) Looks good, I have to do the same thing to my motor.
thanks
matt
Ayuh,... Welcome Aboard Matt,...
Start your own thread about your question, instead of Hyjacking this year old thread...
fat fanny
Chris what was if you don't mind a fellow 3.0 owner asking was the final $ figure on this project? I'm seriously considering the same workup on my 95 LX if the 4 figurure isn't to high before considering something bigger (motor and boat that is). But congrats that poer plant looks great I can't believe I didn't catch this thread in January.
nowback
didn't think I was hijacking,, asked what the cost was of doing the resleeve
and who better to ask my question, someone who has / had the exact same
issue as what I am seeing.
just thought this thread might have insight into this question.
I did see that this thread was a little old but not to bad.
hope the op is still around to maybe give a couple answers.
sorry if I upset anyone
Matt
bigskiohio
i thought you were good i dont get it either . very pertinent questions which i would like answered too. being a year old, bringing back up is a good way to get a answer. i missed this post too.
Status
