Good Afternoon Gents,
I have a 2006 Sea Ray 175 with the mercruiser Alpha one Gen II.
I bought the boat from a fella in Florida, boat ran but would not idle. So I got the boat, taking a chance that was the only issue. I took the TKS off the boat due to how expensive a replacement would be and put an electric choke carburetor on. So far so good, idles and runs great. I then experienced overheating issues. I inspected the impeller which was still in great shape, replaced the thermostat and the water pump. Still overheating. After watching some video on YouTube I decided to "by-pass" the intake/exhaust manifold by using the winterize blue drain hoses. I unplugged the manifold drain and let it dump out the bottom, allowing the water to still enter and cool the manifold but instead of routing through and dumping out the exhaust, it dumps into the hull and out the drain....I did that to test the theory. So, now I am contemplating bypassing the manifold using the drain and drilling a hole on the exhaust side to dump into the exhaust rather than getting stuck in what I'm guessing is rust within the manifold. That will give me a few more years before the manifold rusts out and needing a complete replacement. At that time, I will do it right and replace the manifold and riser. Thoughts?
