I have a 1998 Mercruiser 3.0L (with a Merccarb carburetor) that idles fine (both in gear and in neutral). It also runs fine at cruising speed above 2100 RPM. But, anywhere in the range of 1200-2100RPM, it'll hesitate and slowly lose RPM (at which point I will have to increase or decrease throttle to keep it running). When throttling up from an idle zone, I can't really do it gradually. I have to throttle up quickly past 2100RPM or so. Then, I'm fine. Quick acceleration is fine. Gradual acceleration from idle is not.
Mostly, I've been living with the issue, but lately, I've been thinking about researching the possible cause. I'd be interested in any opinions on what I should check/replace first. I would think a carb rebuild would be my last resort.
