mercruiser 3.8 distributor gear stripped out
I recently put a froze up 3.8 mercruiser back together after many months of work. I took it out for the first test run, it was running great. Three hours later cruising around the lake slowing down to go through a channel and the engine quit with a bad noise. Tried turning it over and it would turn over just no signs of wanting to start. I removed the coil wire to find no spark what so ever. Got a tow back, tore into the motor to find the dist. gear stripped. At full throttle I could only get my RPM's to about 3400 - 3600. Am I getting something stuck in the oil pump and freezing up the dist? Is there any other explanation for this?
