Hi,
I have a 2003 Regal Comodore 2860 with dual mercuirsers 4.3MPI. I was running the boat yesterday; everything was going well (both engines were reaching 3,800 RPM). Suddenly, I heard two beeps and the port engine died. The starboard engine was fine. I was able to re-start the port engine and just keep it under 2500 RPM in order to come back to my dock. Both engines had good oil pressures, 175 degrees temp and the outdrive oil reservoir were in operating range (i re-filled the reservoirs two days ago).
Note:
I was working under the port engine two days ago (trying to reach a screw driver that fell under it). The space is very tight there and I had to go all the way under it. When I started to come back out from under the port engine, I felt like my shorts got caught in something and I heard a soft pop/ like a short air pressure hissing noise (similar to what you hear when you remove the valve form a car tire). I was unable to find the lose hose or fitting.
Is it possible that a fuel vacuum line (or anything related to fuel pressure) is lose and restricts fuel or air at high RPM? If so, where is the best part to find it?
Thanks
Lui
Note:
Thanks
Lui
