Superjetjim
- Joined
- Jun 5, 2010
- 222
Hi, I’m just being a 4.3 out of long term storage (19yrs!) I squirted a couple of shots of engine oil into each plug hole to help with initial turn over - the motor is now free and turning over with good (albeit high, due to the residual oil) compression.
The motor spins over freely on the (new) starter for compression test - but with all plugs back in it barely, if at all turns due to the high comp I guess.
How would you suggest I clean this engine oil out of the bores? Perhaps spray carb cleaner into the plug holes to clean it out as it turns over?
One pot is lower compression than the others, suspecting that valve might need a lap?
Thanks!
Thanks!
