Re: mercruiser 4.3 turn key start
Usually the idle speed is too high when it does this. Also make sure it has the correct spark plugs installed. If they are the wrong heat range (ie: too hot) it may also contribute to the problem. And check the timing while you're at it.
Fix it sooner than later because when it does this there is a risk of water ingestion into the engine.
