Superjetjim
- Joined
- Jun 5, 2010
- 222
Got a strange problem with differing water flow and temp between left and right hand side of engine.
Motor has been stored for a long time, drained antifreeze. Lots of crap brown water came out of blue block drains. Now running clear and reinstalled them. After a min or so of running the right hand exhaust water flow drops. If you drain the block (via the blue plugs) and try again you get decent flow for another min then it slows. Guessing I’ve got build up / debris in the motor - can this be back flushed to remove? Any tips / suggestions like running hose through drain bung hole perhaps?
Observations:
New manifolds
New risers
Water intake is from hose directly to water input.
90’ Elbows are clear / clean on riser input.
Brand new thermostat fitted yesterday
Left riser is cold
Right riser is hot to touch
No water in engine oil (have also checked under rocker covers for moisture and nothing)
Couple of videos attached so you can see the flow difference. See how the flow drops off?
Observations:
New manifolds
New risers
Left riser is cold
