mercruiser 4.3l 175hp down on compresion on cyl 6 only reading 85 psiu
hughesy1
My mercruiser. 4.3l 175 HP is down on compresion but the worst is only reading 85psi and is making an ireguar tapping noise any tips guys?i
tpenfield
Re: mercruiser 4.3l 175hp down on compresion on cyl 6 only reading 85 psiu
Welcome to iBoats . . .
A bit more background and information is always helpful, so that you get good 'on-target' responses. It could be a wide range of issues so more info will help narrow it down.
List all of the cylinders and the circumstances surrounding the issue, etc.
That is my tip for the day.
Ayuh,.... Welcome Aboard,.... With only that tiny bit of Info, I'd guess yer lookin' at a rebuild or replacement...
Do a leak-down test, 'n see if it's the valves, or rings...
tpenfield
85 psi with an irregular ticking noise? Has to be the muffler bearings . . . :D
nola mike
Could also just pull the valve cover and see if anything obvious strikes you...
hughesy1
the fuel problem is dirty fuel i belive, the other cyclinders are pushing 134 - 161 psi it should have 180 also the noise is coming from the rear left when looking at front of engine but its around the area of cyclinder 6 with only 85psi the revs are only 3900 at max and accelartion is well down
nola mike
what fuel problem? Doesn't sound like fuel is causing your symptoms. Your other compression numbers are ok.
hughesy1
fuel problem is uunrelated it was dirty fuel in tank the compresion problem is the one i need answears too thanks
