Mercruiser 4.3L 190hp RPM questions
Rich2010
Hi! I have 2001 Bayliner with Mercruiser 4.3 190hp engine. My question(s) relate to rpm's. I recently changed the water pump (new housing assembly, gaskets, and impeller.) Haven?t had these replaced in recent memories, however the old impeller appeared to be in excellent condition with no rips or breaks in the vanes. Anyway I replaced it and put everything back together. Took it out on the water the other day and noticed that my idle RPM is only about 400. I believe this should be between 550 and 600. While idling for a few min the temp rose above its normal 175 to almost 200-225 and warning light and siren went off. I began moving the boat at a very low speed and the temp immediately went back to 175 degrees. The boat never stalled. I believe the engine is idling to low which is not allowing the boat to get the recommended amount of water thru the engine thus causing it to overheat. I was told that I should just increase the idle screw on the engine a little bit to get it to the normal range. Is that the appropriate solution? Should I be messing with the idle adjust?
On the flip side when WOT it only tops about 3400 RPMs reaching speeds of about 54-56mph. Engine sounds good and runs real smooth. Is it possible the tach is not working properly at higher RPMs? 3400 RPMs seems real low for this engine. Any assistance would be greatly appreciated. By the way my Prop is 14.5 X 19 and was replaced 2 years ago. Thanks
Re: Mercruiser 4.3l 190hp RPM questions
Ayuh,... It sounds like the tach is reading low across the board...
Don S
The tach would be the first thing to check. I doubt the engine would run at 400 rpm in the water.
Cooling might be another problem. Did you replace the gaskets on the water pump housing and under the plate when you installed the impeller? Are you sure you got the gasket on right. If upside down, it will act just like your's is doing. there is one place on the gasket that won't seal right if upside down.
Rich2010
Re: Mercruiser 4.3L 190hp RPM questions
Thanks, Don! Is there any web sight on-line that shows the correct way each gasket shold be put on? Thought I put it back on the same way, but I can see how easily they could have been put on wrong. Thanks Again.
Don S
Go to the Adults Only sticky head to Merc manuals link, and download the service manual (#14) Then go to section 3B page 75.
Rich2010
Thanks Don! Appreciate your assistance. Think of anything let me know. Rich
