Mercruiser 4.3L 4 Barrel Bad fuel pump?
daman4469
I'm back! So a month or so ago, I posted about my Merc 4.3 4barrel acting up. I decided not to try and resurrect that thread. My 4.3 ran fine when I winterized it last year. This year, not so much. It starts in the driveway and idles great...upon getting it on the water, I hammer it and get up on plane. I can run at WOT, or near it. After a few minutes, it starts to fall flat on its face. specifically, it bogs, catches up, bogs. It will do this until it has dropped down to around 2500 RPMs, then it settles down and runs OK. When it first did this (again, about a month ago) I checked (on the water) that the choke was opening up, and it was. all 4 barrels were also opening up. I took it home and posted on here. Many suggestions were to check the fuel filters. I checked the fuel/water separator and the filter by the carb, right where the fuel line connects. That filter was very dirty, but not completely blocked. I cleaned, and took it back to the lake. Boat ran OK for a few minutes again, but the symptom came right back. At this point, I took it to a shop, where they replaced my Ignition control module...said it was weak.
I had assumed things were good, and that they tested it on the water, as i had specifically told them that this only happens under load, not on muffs. Last weekend, we took her out and the same thing happened. 466 dollars later, a clean filter, and a new ICM, the symptom remained.
Today, my boy and I tore apart the whole fuel supply system, from tank to carb. Everything was beautiful and clean. I even ran to the shop and we replaced the ignition sensor under the distributor, as I had one go bad in my old boat and had the same symptoms.
This is why I try to avoid shops. You pay big time and can't return stuff that doesn't help. There is only one close, and I got burned this time. I am thinking about taking it to another shop thats about an hour away (large dealer...good reputation), but wanted opinions first. I think its the fuel pump not keeping up. I could go buy a vacuum gauge and all the tools to diagnose, but with that cost involved I'd much rather spend my time other ways and let a shop do it.
My theory is that the bowl in the carb is full while we idle out to open water. Once we get moving, the boat runs OK until the bowl starts to get low, as the pump can't keep up with the volume. at 120 dollars, I don't necessarily want to just go buy one to try unless some other knowledgable (more knowledagble probably) folks agree with my theory.
Rob
stop throwing parts at it and diagnose the problem
a simple fuel pressure test will tell you if you have a fuel pump issue. most likely it is not the fuel pump, however crud in your carb.
why not replace the filter vs attempting to clean it?
daman4469
Thanks for reading. I don't personally have the skill set to tear into a carburetor; I have tried in the past and had bad luck. The way I see it, if what I have done thus far hasn't been enough to narrow it down to the pump then I'd just prefer to take it to a shop to do the diagnosing; the lake is an hour away from here so driving back and forth to test is a pain. In addition, I could replace the fuel filters but they were miraculously clean, and the only reason I didn't replace was that I would need to drive to a dealer (long drive) or order online, which both are risky on whether or not it will be the right part.
It could be a weak fuel pump but you might have a vacuum being drawn on your fuel tank. If you fuel cap or the vent line leading to the tank is clogged the fuel pump will start drawing a vacuum on the tank. If this is happening and your tank is full, it won't take long to draw a vacuum, if it is more toward empty it will take longer.
To check wait for it to do it, slow down and stop, then loosen cap and listen for air being pulled in.
daman4469
Dodge, thanks for the suggestion. I already tested for vacuum though (actually took my fuel cap off as well as unscrewing it a little, neither worked)....My tank is about 1/2 full.
JoLin
Fuel pickup in the tank is clear with no blockage in the tube or filter screen? Anti-syphon valve is working properly?
daman4469
Tube is crystal clean. pickup is also perfect. great fuel flow to pump. line to carb and carb filter is also clean. my boat is not equipped with an anti-siphon valve, although i think it should be!
daman4469
Took to a shop and let them diagnose. Carburetor was gunked up with pieces of fuel line, filter, etc from the ethanol. Fuel pump was fine. Replaced fuel lines and filters and we are good to go.
