MERCRUISER 4.3LTR EFI 2000-FUEL PUMP
hispeedgas
I HAD A PROBLEM WITH THE ENGINE REVS DYING ,THEN STALLING UNDERLOAD AT 3000 RPM.NOW IT DOES IT OUT OF GEAR.<br />THE FUEL PUMP WAS REPLACED AND STILL DOES IT.I STILL BELIEVE IT'S THE PUMP AS THE FUEL INJECTORS SEAM TO ALTER THEIR SPRAY THEN IT DIES .I HAVE SEEN ON THIS SITE OTHERS THAT HAVE REPLACED 5 PUMPS IN 1000 HRS.<br /><br />WOULD APPRECIATE ANYONES HELP ,THANKING YOU<br />BOB.
tommays
Re: MERCRUISER 4.3LTR EFI 2000-FUEL PUMP
bob<br />welcome and happy new year please turn off the caps lock<br /><br />i am not and efi guy but your going to need the correct service manual for your motor so that you can test the correct parts to track down the problem<br /><br />with out checking things like fuel pressure amoung others in the correct order you willl not get to far<br /><br />tommays
hispeedgas
thanks tommays for responding and i know where your commng from.would you or someone else out there have a pdf file of the wiring diagram and fuel system.thanks for your help and a Happy New Year to you from the land of OZ.
Don S
There is a lot of things that will cause that problem other than the fuel pumps, but there is no substitute for getting the Mercruiser manual and following the troubleshooting charts and using the proper test methods.<br />The worst thing that can happen to the pumps is to run dry. Check the fuel system for air leaks or plugged fittings in the tank. Even run the engine on a remote fuel tank (Such as an outboard tank) to eliminate the fuel system. Do the pressure checkes (Hi and Low)before spending a lot of money on more pumps.
hispeedgas
thanks for your response DON S.I agree about the manual but with it being holidays here,every ones closed .Wehave eliminated the fuel pump as a fault. We swapped pumps with the other engine and the origional old pump is working perfect on the good engine.The pump from the good engine is in the faulty engine and we still have the origional fault.injectors are next, then the computer.If nothing else,we are learning heaps about these motors.<br />thanks guys..............Oh if anybody has a manual please contact me.<br />BOB
tommays
hispeed<br /><br />just wondering how your sure its the injection and not the ignition system if you read through this post and search through the fourms it could easely be eather at this point<br /><br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=24;t=009560 <br /><br /><br />after read this post for weeks i am still confused but i have seen many problems like yours be something as simple as a bad conection on the coil or some other minor part <br /><br />tommays
WillyBWright
Some info about electric fuel pumps...<br /><br />Automotive fuel pumps don't stand-up to marine use. Marine pumps are made of different materials.<br /><br />A fuel pump can burn out from running a fuel tank dry. They can also burn out from sucking enough air.<br /><br />They can also burn out if there is sufficient backpressure after the pump (like a kinked line or plugged filter).<br /><br />With the symptoms you're describing, I'd look real close at the source, not the electrical or pump. I'd guess your problem is plumbing related between the tank and the pump.
hispeedgas
thanks to tommays and willy.<br />appreciate your input . <br />will try your sugestions in the morning.<br />by the way,I was working on the boat when the<br />Tsunami reached us right down the bottom of the west coast.I knew nothing about it.I watched the tide come in and out 9 times in 2hrs.then i knew something was up.a long way away to get the effects hey<br />regards<br />BOB
hispeedgas
Thanks to don s , tommays , willybwright for your assistance. The problem has been solved.this boat is a mates boat and he had said he had blown out the lines between the pump and the tank.the long and short of it was a piece of wood obstucting the skin fitting of the tank.<br />Thanks again<br />bob
jimmythekid
god speed to everyone there, any codes? maybe a MAP sensor? OR Mass air flow?? I dont know much about boats and EFI but I know they have one or the other,<br />MAF OR MAP possibly is spark "going away?" when trying to rev up?? some CAR repeate CAR systems wont energise the fuel pump without a distributor pulse<br />(except for a few seconds at startup) just a thought
