TurnerBFC
- Joined
- Aug 11, 2014
- 98
Hey guys, have done lots of reading about people with similar issues and I've read the traditional cracked block, leaking exhaust manifolds/risers, blown head gasket, etc... Well before I made this post I tried to narrow it down as much as possible for you guys and did lots of digging into it last night. Here it goes:
Motor Serial #D810408, 4.3LX 4 barrel carb.
The boat came out of storage this week after it sat for 2 years without any use... I went to drain the oil from the oil bolt on the pan and a good chunk of water came out and then oil. I went ahead and then removed the spark plugs, and they all looked similar (photo attached). But I did have some water come out of cylinders #3 and #6. Then I removed the port side riser and manifold and didn't see anything obvious (photos attached) then the same for the starboard side (photos attached). Since I didn't see anything obvious here, I decided to go ahead and remove the intake manifold so I could check the underside of it and I've also attached photos here. I don't see any crack in my block, nor in the intake manifold. Unless I am missing something?
I feel like I may be looking at something else... head gasket? Oil Cooler? Maybe just a failed gasket?
Sorry for all the photos - I'm mechanically inclined but when it comes to diagnostics... I fall short :blue:
Any input is appreciated - I know some of the gurus will chime in and help me solve this! I also plan to update this thread when it does get fixed so many people can find their answers based on my issue!
