mercruiser 4 cyl.. to IL6 engine swap
Maako
swapping out a 3.0L 4 cyl. for an in line 6 cylinder, has anyone gone thru this, not sure about the throttle shift linkage plate swap.:confused
Re: mercruiser 4 cyl.. to IL6 engine swap
Ayuh,... The shift plate should be a plug, 'n play swap....
The ratio in the outdrive Ain't though...
