Mercruiser 454 Camshaft
ndjqv
Hello,
My first time in a forum. Hopefully someone can help. I am replacing my boat?s engine. The engine I am installing has a regular truck camshaft. It is a GEN V Chevy 454 C# 10114182. It has flat tap lifters. I need a camshaft that will provide a lot of torque when taking off. The boat is a single engine 28 ft Maxum SCR with a Bravo 3 outdrive.
Which camshaft would be comparable to what a Mercruiser 454 has for a camshaft? Any help will be appreciated.
Thx, Noel
Re: Mercruiser 454 Camshaft
Hello,
Thx, Noel
Ayuh,... It's probably got about the Best cam ya could want in it now,...
A Truck/ RV cam pulls Hard, from Idle to 4800 rpms...
Hello,
Thx, Noel
here is a link to summit racing's list of Comp Cam Marine engines.
http://www.summitracing.com/search/...7-4L-454/?keyword=comp+cams+xtreme+marine+cam
if you havent upgraded other items, and are just looking at the cam, you should keep it pretty mild.
such as
http://www.summitracing.com/parts/CCA-CL11-232-3/
or
http://www.summitracing.com/parts/CCA-CL11-236-4/
truck cams ARE NOT Marine cams.
