Mercruiser 470/170/3.7L Rebuild
Mercruiser420
Greetings fellow boaters,
I wanted to share my 470 rebuild with everyone who may be interested. Hopefully it will be helpful. I will do my best to be as clear as possible.
The boat is a 21' 1977 (pre-alpha) Fiberform Cuddy cabin, with a 1986 Mercruiser 170 but with the 70s exhaust manifold (cast iron) and larger coupler as I didn't want to switch my entire setup to alpha 1 so I kept the exhaust and heat exchanger from the original 1977 motor.
So a few months ago cylinder 3 decided to die on the way back from the Elizabeth islands, in the middle of Buzzards Bay earlier in the summer. I was doing about 3200 rpm when I heard the dreaded "engine damage" noise then the engine died. Fortunately, the other 3 cylinders were enough to get it restarted and I was able to limp home on cylinders 1,2 and 4 only.
Got home safely, started the engine and flushed the system with freshwater and while it was running (very rough) I pulled every ignition wire to see which one(s) made a difference and concluded cylinder 3 to be the bad one. So I performed the following tests:
Ignition/spark test = Pass. All 4 firing.
Compression test = Fail. 145 psi, 140 psi, 30 psi, 145 psi
Conclusion: low compression and the horrific metal crunching noise I heard can only mean that I need an engine/rebuild.
And the tear down begins...
Benny67
How many hours were on the motor before it decided to loose that chunk off of piston #3?
Mercruiser420
No Title
Update: got the engine block back. New sleeve cylinder 3, piston, cylinders honed and new rings. Block was resurfaced. New main and rod bearings, crankshaft checked and polished and camshaft repaired (sleeved) and polished.
