Max-Falcon
- Joined
- Sep 28, 2020
- 18
Hi everyone
I am in a Merc 470 water in oil situation. I get water or coolant (not sure yet) when running engine on muffs. Since I knew at least one case of engine overheat event had taken place, I decided to service the head anyway. Can someone have a look at the attached 2 photos of the head and the block and tell me if they see any clues for leaky HG or anything else. At this point I'd very happy if my HG is bad and issue is not cracked head or block!
P.S. I forgot to drain the AF when I loosened the head bolts so all the AF in cylinder 4 was not there when the head bolts were tight. Also I did not clean anything when I took these 2 shots just to preserve clues!
