Max-Falcon
- Joined
- Sep 28, 2020
- 18
I had water in oil of my Merc 470. After some diagnosis and tests decided to change the head gasket and service the head. Machine shop resurfaced the head, and said no crack or other issues found. Put the head back on with a new marine head gasket (put Sierra gasket not Merc!). Had a little issue installing the pushrods where I bent a few but I got new pushrods that where very close in length but slightly shorter (around 1/32" shorter). before I finish the reassembly and put the exhaust manifold back on, I did a compressing test. I got 150 psi on cylinder 1, 2 and 3 and 100 psi on cylinder 4. All valves seemed to work. I put some oil in cylinder 4 and did compression test again and I got 150 psi. The manual talks about compression test very briefly. It says if I get good compression with oil in the cylinder, then piston rings are the cause! But something tells me there should be more to this! What else could be the reason for my low compression test?
