salty3rd
- Joined
- Jul 13, 2010
- 111
470 overheated the end of last season due to loss of coolant from a hose that broke. I fixed the hose and ran the boat. It was fine for a 20 min run. It cooled a couple hours and when I ran it to go home it started overheating again, I shut it down and did some troubleshooting and couldn't find anything, and the engine wouldn't start again. After some troubleshooting this spring I pulled the head and found a crack. I replaced it with a refurbished head and an OEM gasket. It is running in the driveway but overheats at an idle. If I increase the Rpms it cools it down. The Raw water pump is pumping plenty, and the heat exchanger is clean. The riser elbow is also clear. I have eliminated the raw water side problems and the issue still happens with the thermostat removed. The best I can tell The engine circ pump seems to be pumping. I'd appreciate any thoughts.. Thanks Bill
