I just picked up a 1978 Cruisers Rally with the Merc 470 in it. I have been reading a lot of info on it. The motor runs great and strong. Couple questions:
Mine has a coil and distributer cap instead of points. Does that mean it has been changed\upgraded?
I have read about the problems with the Stator and voltage regulator. That being said, mine charges high at anything above idle. (17V or so) Regulator shot? My Furuno LS6000 does not like the high voltage. Everything else on the boat works fine at the higher voltage. Any way I could drop the voltage for the Furuno? I plan to do the alternator upgrade in the future.
What oil do you recommend? Mercruiser 25W40?
Thanks for the help,
-Eli
-Eli
