saltydogjeff
- Joined
- May 12, 2013
- 145
I got my boat out on the water, and initially, it runs great. I can steadily run with no problems (longest being about 20 minutes at 3000 rpm). Then I stop and go fishing for a little bit. I've noticed after the last two times, after I break, I start up the engine, idles fine, but then when I get up to cruising again, the engine will stall out unless I go into low revs. I think it has something to do with the gas, because it is the same tank of gas that was in the engine when I bought it, and I believe it is about a year old. I would say its the gas, but also, when I hear the engine running, I hear the carb spraying fuel into the intake, and it sounds like when I try to run higher revs and it is having a tough time getting power, that I don't hear fuel spraying through the carburetor. I think this could be a fuel filter problem, because I removed the fuel filter on the fuel pump previously because of fuel delivery. Maybe something in the lines is getting clogged. Has anybody run into this issue before?
