Re: Mercruiser 5.0 Alpha one has no reverse and stays in gear
I have a 1988 4.3L Alpha One and I'm having the exact same symptoms.
The thing that's confusing to me about this is that reverse won't engage even from neutral. If I start the engine it will go into forward but then won't come out of forward until I turn the engine off. This seem consistent with the cutout switch not activating properly to shift out of forward.
The part I don't understand is, when starting from neutral, moving the remote control to reverse moves the shift cables but it remains in neutral, the engine just revs. Does the cutout switch need to activate to shift out of neutral or does it only engage when shifting out of forward and reverse?
Just to give the full story, I also recently replaced the remote control and remote cables because the remote control was jamming up. It was very difficult to move the lever into reverse and sometimes it would jam and not move the shift cable into reverse. It's likely that when I installed the remote control I didn't properly adjust the remote shift cable. I did have one successful voyage though. I had to slightly adjust the cable once in the water the first time so it would move into neutral when the remote control was in neutral, but it was working great at that point.
(I promise to post back with the final solution when I get this fixed!)
