Mercruiser 5.0 closed cooling conversion?
i have a 1994 mercruiser with alpha one outdrive. i am considering converting this to a closed cooling system but can i do this without adding a water take up pump? Market converstion kits do not include a pump and seloc manuals show there is one at time of factory install.
Haut Medoc
Re: Mercruiser 5.0 closed cooling conversion?
You do not need it, the pump in the drive is sufficient.....;)
Don S
It's recommended that you not convert to a closed cooling system after 125 hours or 1 years use. Especially if it was used in salt water. Corrosion has already started and rust will flake off and clog the passages in your new heat exchanger.
dan t.
I converted from a block only fwc system ,to a closed cooling system 4years ago. I removed the manifolds ,removed all the plugs,baked them in a barbicue on low heat for 1 hour,blew them out with air, this removed a lot of rust and scale.I then replaced the plugs,filled them up with muratic acid and let them stew for 1 hour.I rinced them out with water,lots of water,then blew them out with air again. I use only the water pump in the leg,this system has worked perfectly for 4 years and runs at 160 at low speed,180 under load
DrCox
What is the reason that someone would convert to a closed water cooling system? Advantages / disadvantage?
-DrCox
mylesm260
Protect your engine and manifolds (if you decide to include your manifolds in your closed system) against 2 things.
1: Corosion from fresh/salt water
2: Cracking from freezing in the winter time
It is my understanding that manifolds and risers have a fixed life spawn when raw cooled. But when fresh cooled (antifreeze) they will last forever (well the manifolds will, the risers are always subjected to raw water)
