I am chasing the usual overheating issue in my Mercruiser 5.0 Alpha 1 Gen 1 with SN OA623969
It is the open open cooling system with the check balls.
I am trying to diagnose as much as humanly possible in the driveway since it is a 2 hour drive to any water big enough for this boat.
When I put water into the check ball hose to the top of the manifold it just pours out the hose that goes to the bottom of the manifold even if I hold them over the risers. Would this indicate the riser is crudded up or is it that much easier for the water go there instead of through the riser and out the back?
