salty3rd
- Joined
- Jul 13, 2010
- 111
Gentlemen, I recently purchased a Sea Ray with twin 2002 5.0 Mpi bravo 3's. The steering pins on both transom assemblies needed replacing. Instead of cutting into the transom assembly, I removed both engines and transom assembles to make the repair. After reinstalling and hooking the port engine up, I turned the ignition on, the gauges acted normal but the fuel pump didn't come on and I didn't get the audible tone like normal. The engine will turn over if I go to the start position. I checked the basics, loose connections, etc..The three fuses by the relays were all good however only the middle fuse had 12 volts on it..Any ideas on where to go from here is appreciated..Thanks in advance..
